OCD Solutions
- Rentz, GA
I stand corrected, it would still happen at the same time, just in a different place.
I agree with waxhead. It is most likely you got water in there and hydro locked it. When that happens, the piston stops abruptly and the crank will try to keep spinning, and twist out of index, and/or bend the rod like that. If the crank is welded, the damage can be worse. When cylinder one is at top dead center, cylinder two is no longer at bottom dead center. You should check it with a degree wheel. They are just pressed together. so it probably the rear rod that is bent? Then when the rear cylinder locked, the front half of the crank kept going, and since the timing magnet on the flywheel is timed/fixed to the front cylinder, when it fires the rear cylinder, the timing is too advanced (b/c the rear piston is not where it should be) and it backfires. If it happened on the front cylinder, it would just retard the rear cylinder timing, and you would have just lost some power. Of course you could have just sheared a flywheel key AND bent a rod. Spend some time diagnosing, and don't be a parts changer.
I would say the overheating caused it, but usually if its that bad the rings stick too.You can also tell by the wear pattern in the cylinder. Must have happened last season when my oring on the head went bad and I wasnt getting proper cooling. My pissers were sputtering and engine must have got hot. But after I fixed the oring, I did get quite a few more good rides out of it. Makes me think I had two problems.
1. A bent rod
2. Msd going out.
