D-Roc
I forgot!
- Dirty River Rider
just a wild stab, but did you do your leak test with the flywheel cover on? I was thinking that if you did have a bad front seal into the cases and tested for leaks with the sealed flywheel cover on then that could show the bad leak as being slow. then when you start it up it grabs air from in the flywheel area and goes lean.
