is this right SX's came stock with an 80mm Nozzle
When I had a Superstock and Limited SXi we used the 900STS nozzle.
You had to weld side boss's on and we used the Sato ring and steering.
This was the setup that Team Kawasaki used in the 98-2002 tours. Not all the boats would have this but some did some times and some just had the Sato nozzle setup. I have two of the nozzles on my shelf with the upper and lower boss's cut off just never welded the side boss's on.
in 03 I bought a 142mag pump instead of my 140mm mag so the nozzle would no longer work.
They will bolt up to any 92-09 Kawasaki Sx,Sxi,SXR
