Super Jet Is this the correct bolt?
550headache
tobacco grower
tobacco valley
Is this the correct bolt for the flywheel? If so what torque?
Any lock washer or loc tite?
Sent from my iPhone using Tapatalk on the farm.....
JetManiac
Stoked
orlando
Correct bolt
47 ft lbs.
Yami says dry, but some use loctite. Oem flywheel properly torqued wont need it.
lube the flat underside of the capscrew head if you want to be nice to it but leave the threads dry as stated above. Dry torque is less than wet (lubed) torque. Google it.
