Sure. A hall effect sensor also puts out a signal roughly 0-1VAC and has two wires.
The SXR uses a digital DC-CDI (see specs on Kawi's website if you don't believe me).
As such, it wouldn't use the older pulser coil setup.
If you still don't believe me, check out the parts microfiche, section "Generator", and look at the small rectangular box coming off the stator leads.
That is the Hall effect sensor.
The coils on the stator itself are lighting and charging coils.
You will find identical setups on the Yamaha ignitions (760/800/1200/1300)
You're wrong on the SX-R using a pulser coil. Not trying to give you a hard time, please don't misunderstand me.
Btw, this applies to all years of the SX-R.
And if you want another angle to look at it, if it were indeed a pulser coil setup, the ignition would cease to work once you knock all the magnets (sans lobe) off the flywheel.
Wrong
03 sxr had pulse coils on the stator
