Super Jet Is this what they call pitting?What next
munki63
Epoxy is my duct tape
Canada
So Ive started getting my ski ready for next year, selling parts, buying parts... So I did a compression test just to do one, 160/130 thats odd I thought there is only 1 season on the top end...Lets take a look
What happened? the other cylinder/dome are mint! and then there is this...there is also a decent "scratch" in the sleeves
What are my options?
Something in your motor came apart and bounced around. You need to tear that motor down to find the cause.
You also need a bore & new pistons, and new domes.
No. The two sides are pretty well isolated from one another.
If you lose a rod bearing in one side, it won't show up in the other side.
munki63
Canada
I never noticed any problems with the ski when the season was over...thats kinda the weird part, last season the ski dieseled on twice??
If it was a bearing wouldnt i notice something..funny? lol
Piston ring, pin-clips,spark plug,pin-spacer -washer,rod baring,rode spacer, oem reeds,whatever it was ..... take the engine apart and take your time inspecting it precisly, good clean up after damage is found, and then as matt said, new bore/hone/pistons etc...
munki63
Canada
Or send it to X-metal....get a 771.... this will be the 2nd time this f***ing thing will need to be rebuilt, last time I took it to a local guy
Proformance1
Liquid Insanity
New York Crew
I always say the disassembly and investigation is the most important start to a new build. If you don't know why it went bad you'll relive the problem again. When I had my shop I didnt even like to touch an engine unless we took it apart. You'll find the issue, just take you time, look at everything involved, well assuming you have done this type of thing before. By the looks of it, I'd have the crank gone through also.
munki63
Canada
Found it...lol how the heck does this happen??
My next worry, what kind of damage would/could this do to the cases/crank?
Depending on how the bearings feel, I might use the crank as-is in a stock application where I don't care if the motor blows up.
In a pro-ported motor or even an aftermarket cylinder - no way, no how.
munki63
Canada
are you talking about the crank & cases or just the bearings?
edit
just took a closer look at the crank/cases/rods they all look pretty god other then some minor scratches in the case...not sure how big a deal scratches are...
Proformance1
Liquid Insanity
New York Crew
How many hrs are on the crank. My 05 had about 350 on it, it looked fine but I wasnt sure, so I had Pat pull it apart and one rod and one bearing were going, so good thing I did. If you have alot fo ride time on it, replace it. Its not worth the time and effort to have it go again on you.
munki63
Canada
Ive probably got about the same amount of hours on it as you had, other then just spinning it and feeling for imperfections are there other tricks to checking out if your crank is ok, Ive done lots of wrenching but never touched the cases or crank
#ZERO
Beach Bum
Florida - U.S.A.
Don't bother with checking it, your lower rod bearings are toasted and SBT cranks are 200 bucks.
