Freestyle Iso !!! 150mm set back prop lower that a 9/17 for a torrent 150 mag pump.. am i the only dumb one to go 150mm and not 155???
Are you running this with a 964 TPE? What hull? Some hulls will not support a 155 pump. That was the case why I put a 150 in my M1 and it ripped. Ran a 10/18 and the thing was a monster. 49 full specs, msd enhancer, wet power factor on my motor.
Yes a tpe 964 in a roid eme hull sbn duel 46 with power factor lay down pipe and zeeltronics. Ski screams at top end. I have had may people say go 155 but I figured I would try to source a different prop first. I should have gone with a 155 from the beginning then props are readily available not just through 1 guy
Impros can bend your 150 impeller lower if you need it. Actually my 150 on my 964 had more bottom end than a 155 I tried with it. The 155 had more up top.
