- Florida
Looking good keep the pictures coming You doing anything to the back now
Costs an arm and a leg too, I have always watered to rocker a SN just because I think they look awesome but not sure I'm ready for that big of a project.An easier route (and possibly better) would be to get a kit from carterB. Tested tried an true rocker nose, templates, the whole 9 yards.
Another route, take everything out of the ski including thd nose foam. Hang it by the back of the ski up on the air with the nose facing down. Pour 2 part foam in the nose and let cure. After it cures, put the ski on the stand. Cut away the nose with a precise cutter, leave the foam in tact. Reshape the foam the way you want it, glass over it from thd outside. Let that cure, cut out the 2part on the inside, reinforce from the inside.Costs an arm and a leg too, I have always watered to rocker a SN just because I think they look awesome but not sure I'm ready for that big of a project.
That was how I was going to do it step for step if I did it.Another route, take everything out of the ski including thd nose foam. Hang it by the back of the ski up on the air with the nose facing down. Pour 2 part foam in the nose and let cure. After it cures, put the ski on the stand. Cut away the nose with a precise cutter, leave the foam in tact. Reshape the foam the way you want it, glass over it from thd outside. Let that cure, cut out the 2part on the inside, reinforce from the inside.
This square looks badass dude, good job.
