- Central Jersey
Whats up, pretty new to the site but not new to riding. I have been buying a bunch of parts off of people on here and I am finally making some progress, so I figure I post up my build. I was going to waste more money on my 05 SXR, but I decided to get smart and pick up an SJ. In December, I picked up a hull off here from a guy in va that striped the hull, put in a set of footholds, reinforced, refoam, smoothed all scratches in it, and sprayed it with an epoxy primer. A bunch of time and money later, I finally have all the parts I need, finished the final body work and spray the hull. Its nothing special compared to what most guys have on here, but heres what I got for now:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1lace w:st="on"><st1:City w:st="on"></st1:City></st1lace>
<st1lace w:st="on"><st1:City w:st="on">HULL</st1:City></st1lace> AND STEERING <o></o>
96 RN <st1:City w:st="on"><st1lace w:st="on">Hull</st1lace></st1:City>: Painted Jeep Wrangler- Rescue Green Metallic, 17 oz Biax Reinforcement throughout, 1 Layer of Carbon on sides- Clear Coated, Gun metal gray Base/Cleat coated engine compartment, One-way dumped in pump area<o></o>
Stock Hood w/ Blowsion Carbon Liner<o></o>
R&D Intake Grate<o></o>
Wamiltons Ride Plate- Going to D-cut it<o></o>
Rebuilt Midshaft Housing<o></o>
New Stock RN pole- Cut -3"<o></o>
Xmetal Lowered Bracket
Xmetal Pole Bolts<o></o>
Xmetal Adjustable Steering System<o></o>
Xmetal Throttle Lever<o></o>
WCF Chin Pad<o></o>
X-Metal Hood hooks- Hull Side<o></o>
25mm underpadding and Black turf<o></o>
Jetmaniac Hood Strap<o></o>
Rotary dash bilge switch w/ Blowsion Guard<o></o>
Single Rule 500 Bilge<o></o>
Black 45 bilge outlet<o></o>
Front Tow loop w/ Bow Eye<o></o>
Primer kit (plunger style)<o></o>
ODI Ruffian Grips<o></o>
<o></o>
MOTOR <o></o>
61x/62t Freestyle Ported cylinder and Cases<o></o>
82.5 Pro X Pistons <o></o>
New Stock Dual 38 Carbs w/ Stock FA's<o></o>
Pro Designs- Cool Head- Girdled <o></o>
New Factory B-Pipe<o></o>
JetWorks flow control valve<o></o>
Cold Fusion Kawi style Couplers<o></o>
New fuel lines<o></o>
New cooling lines throughout
Kenny Engine Keepers<o></o>
<o></o>
ELECTRICAL
MSD Ignition
JSS Coil
Deka ETX9 battery
<o></o>
PUMP
Jetmanic Bored Exit Nozzle<o></o>
Wamiltons Stubby pump cone<o></o>
Rebuilt Pump and New Wear Ring<o></o>
Solas Prop- Sending it to Impros to repitch to 13/17
<o></o>
<o></o>
WCF Chin Pad<o></o>
<o></o>
MOTOR <o></o>
<o></o>
ELECTRICAL
MSD Ignition
JSS Coil
Deka ETX9 battery
<o></o>
PUMP
<o></o>
<o></o>
