Jet Dynamics vs Worx 205d pumpstuffer
link
LFR
oz
I have had 3 diff jetdynamics scoops, std SST, deep SST & std (old style) on superjets, all of them will hook-up better than the Worx 205 with the stuffer on it.
The Worx 201 is a good thing, hooks-up well, the 205 is a bit faster but less hook-up, the stuffer is for speed only, it makes the rear of the ski loose, you un-hook in turns ect....
We raced with them (modified, opened up) because we had to, I would never use one on a rec ski.
My freeride superjet has a jetdynamics short rideplate, deep SST grate & pumpshoe, it runs the same speed as the rest of the crew I ride with on glass but walks away in chop, its the best setup I have ever used....
You need to work out what you want from your ski, just top speed or the ability to turn so hard you get your head wet & still stay hooked-up....
IMHO you cant have both.....
Big Kahuna
Administrator
Tuscaloosa, AL
Big Kahuna which do you prefer? Thanks
Neither..............
Std Worx
The stuffer grate gives good hookup, added speed, but not really the best for freestyle, the stuffer part is known to break free and also will break the plastic pump shoe....... If you are going to run one you need to change to the JD Alum Pump Shoe.
