JetManiac wants your jet ski core parts and garbage!!
We will doing our forth annual daytona core drive again this year. We are looking for core parts for rebuild, etc.
Bring your core parts to JetManiac booth and turn them into JetManiac credit for any new or used parts and JM apparel.
Choose JetManiac parts credit or donation to the freeride charity.
Core Parts needed:
Core Cranks for yamaha 650/701/760 (rod and bearing condition not important) 20.-25.
and kawi 750/800
Couch driveshafts (WR3, waveraider, waveventure, XL700, GP760/800, etc.) 20.-40.
Ignition coils for yami 650/701/760 (with ebox grommets preferred, but wire/boot condition not important) 10. With grommets or Freeride Tshirt
61x cylinders (needing bore ok, needing sleeves ok, but casting must not be damaged significantly) 50.-135.
Metal Reduction/exit nozzles -650WR3, 701 SJ, venture, raider, XL700
(Yami 144mm and 155mm sizes)
steering nozzles -SJ, VXR, raider
62t Stators / 62t flywheels
Dead OEM Starters
Seized sunk locked motors
Crusty ebox crap and droppings
Steering cable ends and hull fittings
Rubber Straps (battery box, waterbox, misc.)
Bedplate and Case Bolts -oem hull and motor bolts (case, bedplate, etc.)
(Rhass isnt taking using core mounts so not buying old mounts anymore.)
Core parts are reconditioned, rebuilt, or remachined for you to keep you riding.
Thank you for your support!!
Core Parts needed:
and kawi 750/800
Dead OEM Starters
