JetManiac Black Friday doorbuster deals
JetManiac
Stoked
orlando
Early Black Friday is here at JetManiac!
JetManiac has been working for months to find inflation busting deals for you. More deals will be added each day.
Quantities are limited, so get yours now.
Doorbuster Deal 1: Jetinetics 62t billet lightweight flywheel
Jetinetics 62t billet lightweight flywheel $795. Black Friday doorbuster sale $649.
*4 in stock at this blowout price.
Hardened steel hub for reliability, billet anodized aluminum for light weight, heat treated ring gear, embedded magnets, 1 year warranty, fits any Yamaha setup with a 62t stator.
Doorbuster Deal 2: UMI Blaster billet steering system
UMI Racing billet steering system for WaveBlasters $550. Black Friday doorbuster sale $475.
*4 in stock at this blowout price. (Edit: 3 left)
* Newest design.
* 1" taller steering head height
* Steering head now works with standard (7/8") or fat bars (1 1/8"), and includes extra steering top plate and adapter.
* Steering is now anodized in Black.
* Steering arm is longer with more quick steering adjustment.
* Fits 1993-1996 Yamaha WaveBlaster 1
Doorbuster Deal 3: Push/JM intake grate
New JM/Push Intake grate $199. Black Friday doorbuster sale 145.
*8 in stock at this blowout price. (Edit: 7 left)
This is a reproduction of the R&D aquavein intake grate. It is an aggressive scoop intake grate with secondary rear scoop with wings to fully load your pump.
It fits 1996-2020 RN SuperJets, 1990-1995 SN SuperJets, and 1993-1995 Waveblaster 1 skis as well as most a/m hulls using a SJ intake grate.
This intake will help keep your ski hooked up in all conditions. It is awesome performance for freeride and also for racing.
Doorbuster Deal 4: Solas 9/15 Big Hub Impeller
Solas has had a price increases, so JetManiac make a big purchase just before the price increase, and also negotiated a volume discount on the special buy.
Solas 9/15 144 big hub/concord freeride impeller $309. Black Friday doorbuster sale $229.
- Impeller includes rubber nose impeller seal, and Solas impeller tool.
- fits all Yamaha 144mm pumps. SuperJet 1990-2020 and WaveBlaster 1 1993-1996.
- Perfect for stock oem 144 pumps or Solas mag pumps.
** Quantities are limited on these.
Doorbuster Deal 4: ADA girdled head kit -Silver takeoff
ADA girdled head kit complete for Yamaha $385. Black Friday doorbuster sale $309.
(includes Silver demo/takeoff new ADA girdled head shell, new girdle kit, 2 new 701/35cc, 760/38cc or other sized ADA domes, Orings, hardware)
*Just 2 in stock.
Optional as pictured below add:
JM bling allen cylinder head stainless bolt kit (10bolts/washers) $29. Sale 17.90
Doorbuster Deal 5: ADA girdled head kit -New Black, Blue, Red
ADA girdled head kit complete for Yamaha $385. Black Friday doorbuster sale $329.
(includes new BLACK, BLUE, or RED ADA girdled head shell, new girdle kit, 2 new 701/35cc, 760/38cc or other sized ADA domes, Orings, hardware)
*2 of each color in stock at this price
Doorbuster Deal 6: Solas Yamaha 144 MAG pump
Special purchase! JetManiac was able to buy several Solas mag pumps again at very special pricing.
Solas 144mm 12 vane Stainless MAG Pump stator $579. Open box Black Friday doorbuster sale $399.
*Includes Solas pump cone and Stainless hardware
(3 only)
*Fits all years Yamaha Super Jet and Blaster 1 and uses the standard stock length driveshaft.
Doorbuster Deal 6: Solas all stainless wear ring
Solas 144mm stainless wear ring/impeller housing $359. Open box Black Friday doorbuster sale $269.
(3 only)
JetManiac
Stoked
orlando
Doorbuster Deal 7: PHP intake manifold - VForce 3 reeds
index.php
PHP (PowerHouse Products) has designed what many (including us at JetManiac) feel is the best designed intake manifold for Yamaha twin carb motors. This is a state of the art freestyle intake manifold for 62t or 64x Yamaha cases, not a manifold designed for the needs of high RPM racing. We have installed and tested them on PHP, DASA, and JetManiac/Blue motors with great results.
index.php
This intake was designed specifically for freestyle performance. It features a shorter and better designed intake track shape for more freestyle low end performance. The manifold is a 3 piece design with a removable O-ringed billet carb base plate which makes removing and reinstalling carbs easier while preserving carb linkage alignment. The manifold itself is 2 piece for future compatibilty with longer crankcases cases in development at several companies. Only a longer speed plate will be required. Removable throttle cable bracket is included.
PHP manifold is designed to work best with VForce 3 reeds and cages, but will work with stock, VF2, or other reeds/cages setups. Manifold inlet is a perfect flow fit to the larger sized VF3 reed stuffers.
PHP intake manifold $398. JM Sale price 349.90 **Black Friday doorbuster sale $319.
(Includes PHP manifold, dual carb speed plate, throttle cable bracket, carb base gaskets and all SS hardware for carbs, plate, and to cases)
*4 at this price
VForce 3 reeds/cages system $259. **BF Sale price $219.90 with manifold purchase
(includes reeds with VF3 custom cages and gaskets to motor and to manifold)
(*4 at this price)
index.php
Doorbuster Deal 8: ADA nongirdled head kit
Wow those look purdy!
1 each of silver, black, red, or blue.
ADA nongirdled head kit for Yamaha 701/760 $300. Black Friday doorbuster sale $259.
(includes ADA nongirdled head shell, 2 open box/demo ADA 701/35cc or 760/38cc domes or your choice if in stock, Orings, and brass water fittings)
Optional add:
Doorbuster Deal 9: VForce 2 reeds/cages
The V-Force 2 Reed Valve uses a double row cage design for additional flow at all RPMs. Reed stops and rubber over-molded cages extend reed life and eliminate petal distortion. Specially developed carbon fiber reeds offer the ultimate in response and durability. The V-Force increased flow results in significant horsepower gains with freestyle pulling torque and broader peak horsepower...
Open up and Say 'AHHH!' Let your motor breathe with two rows of reeds instead of one.
VForce 2 mounted on stock/oem intake manifold for dual 38's. Also fit with stock/oem dual 44 manifolds and most a/m manifolds as well.
We have used VF2's in stock 701/bpipe setups, in ported 701s, and Big Bore ported 781's with excellent results for freestyle or racing.
VForce 2 reeds/cages system $259.90 Black Friday doorbuster sale $229.80
(includes reeds with VF2 custom double row of carbon reeds with VF2 cages and reed gasket for manifold to cases)
Doorbuster Deal 10: PJS Kawi 750 Mikuni single carb intake manifold
PJS Kawi 750 Mikuni single carb intake manifold $210.05 Black Friday doorbuster sale 188.90
High quality USA made manifold has integrated throttle cable mount and includes gaskets, stainless allen intake studs, and carb base flange nuts.
Doorbuster Deal 11: Solas Yamaha 148 MAG pump
New Solas 148mm 12vane SS MAG Pump stator $649. **Black Friday doorbuster sale $439.
(Includes solas pump cone and ss hardware)
*2 only at this deal
Doorbuster Deal 12: Solas 148mm stainless wear ring/impeller housing
Solas 148mm stainless wear ring/imp. housing $392.59 Open box Black Friday doorbuster sale $289.
(2 at this price, when purchased with 148 pump stator deal)
Doorbuster Deal 13: JetWorks Pro flow control valve
Flow Control Valves dry out the waterbox at low rpm for more low end power for freestyle or racing.
JetWorks FCV blue Pro adjustable flow control valve $55.95 Black Friday doorbuster sale $45.89
(screw valve body in/out to adjust)
Doorbuster Deal 14: Aluminum cast throttle lever
Black Aluminum cast throttle lever $36.95 Black Friday doorbuster sale $25.89
10mm cable threads fits older Kawi cable w/o adapter, Yami 6mm or Later model Kawi 8mm need an adapter
Hey Chris , I'd like to get my name on a Solas , 9/15 concord, Solas 144 mag stator section , and Solas 144 wear ring. Let me know how I go about ordering from you in Ontario , Canada. Thanks , Cheers
JetManiac
Stoked
orlando
Brappin' BOGO sale too.
I need a 701 crankshaft
