JetManiac Black Friday Doorbuster deals!
JetManiac
Stoked
orlando
Black Friday Doorbuster deals start now at JetManiac!
JetManiac has been working for months to find inflation busting deals for you.
More deals will be added each day.
Quantities are limited, so get yours now.
JetManiac BOGO sale also drops soon.
Doorbuster Deal 1: PUSH Yamaha 144 aluminum pump shoe $135.
Here it is, an aluminum pump shoe that actually fits!
PUSH aluminum SJ/B1 144/148 pump shoe $169. Black Friday doorbuster sale $135.
*Designed like the oem shoe with plenty of room for adhesive to lock shoe into position.
*All holes are there just like an oem shoe. No drilling or tapping or malarkey required.
PUSH it, push it good! PUSH it real good!
Doorbuster Deal 2: PUSH SJ/B1 intake grate $149.
New JM/Push Intake grate $199. Black Friday doorbuster sale $149.
*10 in stock at this blowout price.
* This is a reproduction of the R&D aquavein intake grate. It is an aggressive scoop intake grate with secondary rear scoop with wings to fully load your pump.
* It fits 1996-2020 RN SuperJets, 1990-1995 SN SuperJets, and 1993-1995 Waveblaster 1 skis as well as most a/m hulls using a SJ intake grate.
* This intake will help keep your ski hooked up in all conditions. It is awesome performance for freeride and also for racing.
Doorbuster Deal 3: PUSH pump shoe/intake grate combo
PUSH aluminum pump shoe/intake combo $368. Black Friday doorbuster sale combo $269.80
*Save even more on this hot PUSH combo!
Doorbuster Deal 4: UMI Blaster billet steering system $459.
UMI Racing billet steering system for WaveBlasters $550. Black Friday doorbuster sale $459.
*Only 3 in stock at this blowout price.
* Newest design.
* 1" taller steering head height
* Steering head now works with standard (7/8") or fat bars (1 1/8"), and includes extra steering top plate and adapter.
* Steering is now anodized in Black.
* Steering arm is longer with more quick steering adjustment.
* Fits 1993-1996 Yamaha WaveBlaster 1
Doorbuster Deal 4A: UMI X2 billet steering system $289.
UMI Racing billet steering system for X2 $450. Black Friday doorbuster sale $289.
*New, but has a few scratches from shipping.
*Black anodized with quick turn steering arm.
Doorbuster Deal 5: ADA girdled head kit -Silver takeoff
ADA girdled head kit complete for Yamaha $405. Black Friday doorbuster sale $309.
(includes Silver demo/takeoff new ADA girdled head shell, new girdle kit, 2 new 701/35cc, 760/38cc or other sized ADA domes, Orings, hardware)
*Just 2 in stock.
Optional as pictured below add:
JM bling allen cylinder head stainless bolt kit (10bolts/washers) $29. Sale 17.90
Doorbuster Deal 6: ADA girdled head kit -New Black, Blue, or Red
ADA girdled head kit complete for Yamaha $405. Black Friday doorbuster sale $329.
(includes new BLACK, BLUE, or RED ADA girdled head shell, new girdle kit, 2 new 701/35cc, 760/38cc or other sized ADA domes, Orings, hardware)
*2 of each color in stock at this price
JetManiac
Stoked
orlando
Doorbuster Deal 7: Mikuni 44 or 46mm racing carburator
Mikuni 46mm racing carburator $300. Black Friday doorbuster sale $219.90
- New racing carb with primer fitting installed, and T handle adjusters included
Mikuni 44mm racing carburator $259. Black Friday doorbuster sale $187.90
Doorbuster Deal 8: VForce 2 reeds/cages
The V-Force 2 Reed Valve uses a double row cage design for additional flow at all RPMs. Reed stops and rubber over-molded cages extend reed life and eliminate petal distortion. Specially developed carbon fiber reeds offer the ultimate in response and durability. The V-Force increased flow results in significant horsepower gains with freestyle pulling torque and broader peak horsepower...
Open up and Say 'AHHH!' Let your motor breathe with two rows of reeds instead of one.
VForce 2 mounted on stock/oem intake manifold for dual 38's. Also fit with stock/oem dual 44 manifolds and most a/m manifolds as well.
We have used VF2's in stock 701/bpipe setups, in ported 701s, and Big Bore ported 781's with excellent results for freestyle or racing.
VForce 2 reeds/cages system $259.90 Black Friday doorbuster sale $229.80
(includes reeds with VF2 custom double row of carbon reeds with VF2 cages and reed gasket for manifold to cases)
Doorbuster Deal 9: PHP intake manifold - VForce 3 reeds
index.php
PHP (PowerHouse Products) has designed what many (including us at JetManiac) feel is the best designed intake manifold for Yamaha twin carb motors. This is a state of the art freestyle intake manifold for 62t or 64x Yamaha cases, not a manifold designed for the needs of high RPM racing. We have installed and tested them on PHP, DASA, and JetManiac/Blue motors with great results.
index.php
This intake was designed specifically for freestyle performance. It features a shorter and better designed intake track shape for more freestyle low end performance. The manifold is a 3 piece design with a removable O-ringed billet carb base plate which makes removing and reinstalling carbs easier while preserving carb linkage alignment. The manifold itself is 2 piece for future compatibilty with longer crankcases cases in development at several companies. Only a longer speed plate will be required. Removable throttle cable bracket is included.
PHP manifold is designed to work best with VForce 3 reeds and cages, but will work with stock, VF2, or other reeds/cages setups. Manifold inlet is a perfect flow fit to the larger sized VF3 reed stuffers.
PHP intake manifold $449.95 JM Sale price 418.95 **Black Friday doorbuster sale $395.
(Includes PHP manifold, dual carb speed plate, throttle cable bracket, carb base gaskets and all SS hardware for carbs, plate, and to cases)
*4 at this price
VForce 3 reeds/cages system $259. **BF Sale price $219.90 with manifold purchase
(includes reeds with VF3 custom cages and gaskets to motor and to manifold)
(*4 at this price)
index.php
Doorbuster Deal 10: JetWorks Pro flow control valve
Flow Control Valves dry out the waterbox at low rpm for more low end power for freestyle or racing.
JetWorks FCV blue Pro adjustable flow control valve $57.95 Black Friday doorbuster sale $45.89
(screw valve body in/out to adjust)
Doorbuster Deal 11: Mikuni SBN carb rebuild kit
Mikuni SBN genuine OEM carb rebuild kit $63. Black Friday doorbuster sale $46.59
(Fits Mikuni OEM 38mm and 44mm carbs, and Mikuni 44, 46, 47, 48, 49, 50mm Aftermarket racing carbs)
or
Mikuni genuine OEM sbn-I Yami 800/1200 carb rebuild kit $63. Black Friday doorbuster sale $46.59
Doorbuster Deal 12: PUSH Yamaha or Kawi flywheel lock $39.95
PUSH Yamaha flywheel lock $55.95 Black Friday doorbuster sale $39.95
*Fits Yamaha 650/701/760 motors
PUSH Kawasaki flywheel lock $55.95 Black Friday doorbuster sale $39.95
*Fits Kawi 750/800 motors
JetManiac
Stoked
orlando
Doorbuster Deal 13: PJS Kawi 750 Mikuni single carb intake manifold $187.90
PJS Kawi 750 Mikuni single 44/46 carb intake manifold $240. Black Friday doorbuster sale 209.95
High quality USA made manifold has integrated throttle cable mount and includes gaskets, stainless allen intake studs, and carb base flange nuts.
PJS Kawi 650 Mikuni single 44/46 carb intake manifold $225. Black Friday doorbuster sale 199.95
Doorbuster Deal 14: Jetinetics 62t billet lightweight flywheel $645.
Jetinetics 62t billet lightweight flywheel $795. Black Friday doorbuster sale $645.
*4 in stock at this blowout price.
Hardened steel hub for reliability, billet anodized aluminum for light weight, heat treated ring gear, embedded magnets, 1 year warranty, fits any Yamaha setup with a 62t stator.
Doorbuster Deal 15: ADA nongirdled head kit $258.
Wow those look purdy!
1 each of silver, black, red, or blue.
ADA nongirdled head kit for Yamaha 701/760 $300. Black Friday doorbuster sale $258.
(includes ADA nongirdled head shell, 2 open box/demo ADA 701/35cc or 760/38cc domes or your choice if in stock, Orings, and brass water fittings)
Optional add:
Doorbuster Deal 16: Aluminum cast throttle lever
Black Aluminum cast throttle lever $36.95 Black Friday doorbuster sale $25.89
10mm cable threads fits older Kawi cable w/o adapter, Yami 6mm or Later model Kawi 8mm need an adapter
Doorbuster Deal 17: Rotary bilge switch
Rotary 3 position waterproof bilge switch $ 49. Black Friday doorbuster sale $35.95
Add a Watt hole recessed mount for rotary switch $38. sale 33.
Doorbuster Deal 18: SJ or Blaster Monkey grip motor mounts
Monkey Grip SuperJet motor mounts $43./ea. Black Friday doorbuster sale $29.95
These mounts fit: Yamaha SuperJet 650/701 1990-2020
or
Monkey Grip Blaster or FX1 motor mounts $47./ea. Black Friday doorbuster sale $31.95
These mounts fit:
1993-1996 Yamaha WaveBlaster 1 701
1996-1997 Yamaha WaveBlaster 2 760
1994-1995 Yamaha FX-1 701
Doorbuster Deal 19: Solas Yamaha 148 MAG pump
New Solas 148mm 12vane SS MAG Pump stator $649. **Black Friday doorbuster sale $399.
(Includes solas pump cone and ss hardware)
*2 only at this deal
*Fits all years Yamaha Super Jet and Blaster 1 and uses the standard stock length driveshaft.
Doorbuster Deal 20: Solas 148mm stainless wear ring/impeller housing
Solas 148mm stainless wear ring/imp. housing $392.59 Open box Black Friday doorbuster sale $249.
(2 at this price, when purchased with 148 pump stator deal)
Doorbuster Deal 21: Midshaft housing Lynx for Yamaha $118.
Midshaft housing Lynx for Yamaha $159. Black Friday doorbuster sale $118.
*Yamaha midshaft housing including NSK bearing and 3 grease seals installed, ready for grease and shaft
*Fits Yamaha SuperJet 701 1995-2020, B1 1993-1996, and most other Yamaha 701/760 skis.
Doorbuster Deal 22: Bilge switch for Yamaha start/stop mount $84.95
Yami Start/stop switch mount Bilge switch $99.95 Black Friday doorbuster sale $84.95
*mounts to bottom of Yamaha start/stop switch
Bilge switch Kawi start/stop switch mount $97.95 Black Friday doorbuster sale $84.95
*mounts to bottom of Kawi 440/550/750SX/750SXI/800SXR/1500SXR start/stop switch
Replacement handle bar mount bilge switch $80. Black Friday doorbuster sale $67.95
(with 9ft wire harness) fits Blowsion s/s mount and universal bar mount holders
Doorbuster Deal 23: Thrustone 155 setback MAG PUMP
Thrustone 155mm MAG setback pump stator/wear ring $1,200. Black Friday doorbuster sale $1,049.
Open box box -only 1 in stock at this BF deal!
* 155mm set back 14 vane 75mm hub stainless pump stator
* 155mm lightweight aluminum wear ring
* Delrin pump cone
JetManiac
Stoked
orlando
Doorbuster Deal 24: Torrent 148 setback MAG pump
Torrent 148mm MAG setback pump stator/wear ring -Fake news retail $2,299.95 sale 1,295. Blockbuster open box sale $1149.
* 148mm set back 14 vane 75mm hub stainless pump stator and wear ring combo
* Delrin pump cone
Doorbuster Deal 25: Skat Trak 148 setback MAG pump
This is the OG of MAG pumps. Skat Magnum pumps were the original MAG pumps, and still some of the best.
Now that Skat has been closed for a minute, a brand new Skat pump is rare bird. This pump has new seals installed and was getting ready to be built and build was cancelled. It was recently found deep in the JM parts vault, and it can be yours!
Skat Trak 148mm MAG setback lightweight pump stator/wear ring
Fake news retail $2,799.95 sale 1,989. Blockbuster open box sale $1249.
* 148mm set back 14 vane 75mm hub aluminum/stainless pump stator and wear ring combo
* Delrin pump cone
Doorbuster Deal 26: PUSH 155mm Ultra lightweight setback MAG pump
PUSH 155mm lightweight competition setback MAG pump $1,495. Black Friday doorbuster sale $1295.
This black beauty is at the top of the pump game.
Ultra lightweight design and crazy precise vanes will boost you to new heights.
What? Are you kiddin' me??
Cooling fittings where you want them!
Thickened mounting pads on each side with 3 easy positioning options or choose anywhere on the pad.
Doorbuster Deal 27: Boyesen Power Reeds -Dual-flex epoxy fiber 61x or 62t/64x
Boyesen Power Reeds -Dual-flex epoxy fiber Yamaha 701 61x sgl carb cases $79.95 Black Friday doorbuster sale $63.89
Boyesen
Power Reeds -Dual-flex epoxy fiber Yamaha 701/760 62t/64x dual carb cases $89.95 Black Friday doorbuster sale $73.95
more coming. seriously...if we can find more
