JetManiac Waterbox
I ended up going with a tdr. Going to be obnoxious and loud as mid 90s stand ups should be haha. Stock water box holds too much water for me. Will post for sale on here soon
JetManiac is proud to announce our new freeride waterbox. It is designed to replace a stock SuperJet waterbox both in hose connection location and fitment, but it is smaller, lighter and fits better in aftermarket hulls.
We have always been puzzled by the design of many a/m waterboxes.
* There is no more need to cut your expensive long waterbox to outlet hose.
* Inlet is stock sized so standard exhaust hoses and Bpipe coupler to waterbox hoses fit.
* Inlet and outlet are flanged like stock to help prevent a hose from sliding off.
Weight comparisons:
Stock RN 4lb 12.4oz
Xmetal 3lb 13oz
JM 2lb 7oz
* The stock waterbox also holds more water making weight difference in use larger.
* Also this extra water is still in the stock oem waterbox after use and will not all braap out, so is more likely to cause condensation in the open exhaust port of your motor. JM waterbox is easy to brapp out water after riding.
You can see the quality of the welds. All waterboxes are welded by the same certified welder for consistent quality. (AWS D17.1 aerospace certification for aluminum, s.s. and titanium)
Welder is also a rider who understands its use and design. Particular attention was paid to the design of baffle and attachment to eliminate the 'loose baffle' problem so common with stock and some aftermarket waterboxes. Photos are of one of the prototype boxes not the production ones.
We experimented with baffle and box design to give better sound and performance. Sound is louder and throatier than stock, but not super loud like some other a/m boxes.
Size comparison with OEM SuperJet waterbox
JM waterbox body is 8.5" W x 6.5" T x 4" D (angled)
JetManiac lightweight waterbox $239. sale 209.90
I’m interested in getting a Waterbox and midshaft bearing assembly.not sure how to get ahold of you guys.feel free to contact me anytime (510)677-6439
Weight comparisons:
Stock RN 4lb 12.4oz
Xmetal 3lb 13oz
JM 2lb 7oz
JetManiac lightweight waterbox $279. sale 239.90
How can i purchase 1 and will you be at the WORLD FINALS IN LAKE HAVASU
