Is 112.5 low Jet to small ? 701 Ada head mod chamber.... I can't get it to run right keep bogin down from 3/4 to 3 turns out lol....tried all kinda adjustments.. 95 pop of... duel 44 mikuni carbs
I guess it's the weight.
.just said 95 g spring... Some people saying should b 80 or lower.... I know plugs look rich and carbon is building on cylinders so I'm sure jets are OK....maybe need to tune more today or try spring change... It's just falling on its face
You probably have a air leak in your motor preform a leak down test if you're not able to hold around 8 psi for at least 10 minutes you need to reseal your motor I'd guess you won't pass the leak down
I just ordered a leak down tester to check my carb pop of spring and seat pressure first..... I'm thinking and hoping it's the wrong spring..... Start there and move forward
A pop off Guage will only check the psi need to open your needle and seat a leak down check is when you plug your intake and exhaust with whatever you want I use plumbing plugs from home Depot then with a pump you pump up pressure in your cases to 8 psi if your motor doesn't hold the 8 psi you'll never be able to tune your carbs it should take you about a hour it's definitely where I would start when was your motor last taken apart?
I'm not lean or anything but just got a call from a friend in the biz for 30 years and he has me in the right direction ....thnx for the advice everyone ....thank u...
It would be lean only if the leak was between the intake and carbs any other leak will cause the motor to run rich crank seal base gasket ect good luck hopefully it's a easy fix
