- Windsor, Ontario
Ok I'm hoping someone on here is a guru with jetting on superjets... I cannot for the life of me get mine dialed in. Anyone got any ideas for baseline jetting on my setup? Looking for a better starting point cause clearly what I have no is not working, very rough idle, good low end power, crap midrange and top end.
My setup: 760cc 61x top end, 62t cases, both heavily ported, 190-195psi Ada girdled head, msd ignition, stator advanced 2 degrees, vforce 3 reeds, dual OEM 44's,1.5" hot products FAs with blowsion raincoats, choke delete, added primer, b pipe (manifold ported to 52mm I believe), tnt waterbox, dual cooling, lightweight flywheel and couplers, 08 sj impeller.
Sent from my HTC One_M8 using Tapatalk
