I'm going to be running a ported 61x case and ported 61x cylinder bored to 84mm with a bpipe. 44mm stock carb Just wondering if any body has jetting/tuning ideas for this motor. Thanks
160 main 127.5 Pilot 24psi pop off. On my 84mm ported 61x.
Whats stock ported ?Id personally start with closer to what quinc is at. Stock ported 701s usually run around 120-125/150
It might need a little fattening with jyst porting the cylinder . Plus ones persons porting is not the same as someone elses. Some people call cleaning up casting as porting. Thats why the factory page is correct. Its just a suggestion once you get to modding internals cause everyone is different.Stock bore 61x c. inder ported is what I meant.
The answer is not there. Those are suggestions for an untouched 61x cylinder. Porting your cylinder very much changes your jetting..
