Jetting single 44 in a 61x 701 with pipe/head
Hey guys,
Its been a long time but I took some time off to prepare my buddy's ski for the summer.
Its a 95 701 with a single 44, I got him a pipe (which I believe is a factory dry type 2, see attached picture that I found in another post, same pipe but the one I got is totally black with a riva red header). Also I got him a milled stock head to premium gas (175 psi). Except for pipe and head (and I believe different impeller there is nothing else).
What should the jetting be and what does the stock 44 have.
Stock flame arrester stays for now also.
Thanks,
Adam
SuperJETT
none
sjweber has the same setup but a FP ltd and he's currently at 120L/145H but the high screw is almost closed, so will probably end up at 120L/140H. I'm not sure of the popoff, we set that a couple of years ago when we did the head/reeds/etc.
SuperJETT
none
I'm not positive, but I don't think that's the dry version of the Riva pipe. I believe it's the wet version.
Charles
Yes, the water jacket stops 1/3 of the way down the pipe, so it's a wet pipe.
I can't imagine the jetting being that different from 120/145, so that's a good place to start.
jetskiking
Im done sanding!!!
Dallas Georgia
Yes thats a wet pipe. I sold one last year. Like everybody is saying 120/145 would be a good startin point and that would be nowhere close to what you would run with duals.
