Yea I figured that. my neighbor runs a cnc doing something so maybe I can crush the soider and send it to work with him. however I just stuck a 1/6" thick piece of soider into the spark plug hole (bent a 90 0n it and put it all the way to the tray side of both cylinders turning it over multiple times by hand and it did not touch it...
The head should have been brand new with 35 domes. I bought the 33s on here. 5lbs diff between 35 and 33. Ill just get it to the machine shop down the street maybe to check the squish this week. Thanks A LOT for your help!
i dont think those are 33 cc domes. those domes should give you 10-15lbs going from 35 to 33. my ski has 35's but i cut them so unless someone runs my exact setup, its probably not going to be a good outcome. see what im saying? they could have been cut. get your machine shop to measure with fluid the difference between a 35 and 33 dome
you need to know WHAT you have really, i replied to the PM. measure the domes and find out what the deal is with 5lb compression difference. shouldnt be that way. it sounds to me like its a set of cut domes.
I changed them cause he said with 35s I needed one gallon 110 to 4 gallons 93. I added TL and always mix 50/50 anyway so last year he said it was ok to bump it up. WHY IS MY COMPRESSION SO LOW?!? ugh
