N3vrSat1sfied
Military Member
- Fort Worth, TX
Main Jet = 110 H
Pilot Jet = 125 L
Needle/Seat = 2.3
Spring = 95
Pilot screw = adj 3/4 turn out
Main Screw = adj 1.25 turn out
I'm ordering a set of 122.5 and 120 Pilot jets to see if that helps to clean up the low end. I'll update this when they arrive, I have them installed and tested.
My setup is as follows:
Gas Octane = 93
Altitude = sea level
Motor type/setup = bb781 61x/62t, 185 psi, 38cc domes, b pipe w/ mod chamber, MSD enhancer, #ZERO lightened flywheel, Pro-Tec intake manifold and Mikuni 44mm SBN carbs
My setup is nearly identical only difference is I am running stock 64x intake manifold with Main Jet = 115 H, Pilot Jet = 120 L Same springs, and needle and seat. Im like a 1 1/4 turn on top and bottom
