madscientist
chilling with these guys.
- good old p'cola
glad to help.
Oh and I've been out of the loop, and haven't seen this. Mad props. I love it. That should be a hell of a ride. Killer work/ideas. Bring it to Pac City!
You had better let someone with big power handle that, I volunteer....I think I got dibs on test pilot but I gotta make sure with Brent : )
Leave the motor, move your feet and steering back, trust me.So if I read this right, the 900 driveshaft is the same form end to end as the X2, with the exception of the coupler position being 3 inches closer to the bulkhead? So I could set my yamaha engine back 3 more inches if I wanted to use it? Obviously it would require a ton of changes to my bedplate, motor mounts, etc, but theoretically it would be the same, only it would move me back 3 inches?
any updates?!
I've heard some negatives about PSI from other people. But personally I've had good luck with them. Had one of there Mack Daddy Ultras a decade ago , and some machine work done. Great build and engine choice. I too think a Mag pump ( 140mm plus) is in order.
