- New Jersey
starting up a summer build, while i ride my other build that i just finished today. I've only got two pieces so far, a js300 hull in great condition, and a 701 61x which needs to be rebuilt. A 144 pump and cavity mold are bought and on their way sometime this week.
body work:
This will be my first time doing fiberglass work, but i have a lot of plans for the hull. Fitting in the pump cavity is the only thing im worried about getting lined up. IM going to be doing custom footholds and sponsoons. Im not quite sure what i will do with the nose. I want it a bit rockered but ive never really seen a rockered js style hull, so if anyone has some pics, advice or links... id like to see them. Will probably be making a new hood which wonb't be quite as tall and either getting a superjet pole or a PFRacing pole.
Engine:
I got a 701 61x that needs to be rebuilt. Im considering getting a jetmaniac topend, but i also want a b-pipe, so im trying to figure out what will fit in the budget. I still need to test fit the 701 with a b pipe in the hull but since im going to be making a new hood i don't mind making a little bubble to accommodate it. *could somebody give the dimension for how far the b pipe stick out from the cylinder*. Either measure from the surface where the manifold mounts to the cylinder or just take a measurement to the spark plugs.
Will probably start cutting stuff up tomorrow and will take some pics. Waiting to cut the nose up though because i don't know what i want to do yet.
body work:
Engine:
