- riverside ca
ok new to stand ups but im mechanically inclined and will try to understand what your saying. ok so i bout a 88 js300 off a friend for $250 (sat for over a year) and wouldnt start up so i took off the starter unstuck the contacts and not turns over every time. then i wasnt getting spark pulled out the plug wire and split the ebox and came to find out the plug wire wasnt all the way down so there wasnt any contact between the coil and wire so now i have spark. compression is good. onto the issue im stuck on. i dropped some fuel into the carb since the primer system doesnt work and it fired right up no problems dry start. shut it off then 10 minutes later fired it up again (had to drop fuel down) and it revved up as if in WOT without even touching any thing i pushed the kill switch nothing, pulled the spark wire off it and it was still running, didnt want to blow the motor so i unscrewed the fuel pick up and snapped the throttle and it died out..... this happened 2 times. im gonna take a best guess its a carb issue since its most likely just dumping fuel and wont shut off but where do i start?
any help will be greatly appreciated
