Super Jet just another rn sj build
Spokane,wa
since it got really cold really fast here in wa state i decided to start my build early in the season.this what i have done on my sj..
the hull before it when on the shop stand
the motor before it get some new stuff
since i pick up the hull i did a fast spray can paint job on the hull,so i had to strip off the old paint to get the hull ready for a house of kolor paint job
20131008_145859 (1).jpg20131013_160743.jpg20131013_173927.jpg20131013_181724.jpg
Spokane,wa
time to get some repairs done and add some stuff.the bottom of the hull had some minor damage so i got them repaired,trim off rear bond line off and spray the hull with primer sealer and the bottom hull with house of kolor mat black
20130930_171132 (1).jpg20131015_141437.jpg20131015_141844.jpg20131015_192443.jpg
Spokane,wa
so now i got all off the work i wanted done,i started to wet sand the hull to get ready for the base coat this what i came up with.hopefully u can see the ghost skull and the tribal airbrush job
Spokane,wa
motor work,the one to the lift is going to jm for some loving the one in the right is what going into my hull..i painted it with engine paint but i was not satisfied with the work
so i ended up taken it apart to give more bling
Spokane,wa
purchase a lighten flywheel and some gasket from jm
house of kolor candy apple red with a adhesive promotor so the paint well stick to the motor
20131118_124232.jpg20131118_171600.jpg20131118_171902.jpg20131118_215458 (1).jpg20131118_215514.jpg
Oregon
Looks awesome! Two questions: what hood is that, and did you switch gas tanks? (The last pictures are not internal fill, so I'm curious if you switched back to external fill?)
Edit: this was a stupid question. I was comparing the location of your internal fill.
Spokane,wa
it a jk freerider hood from blowsion,no i never when back to external fill
Do you paint skis in Spokane? I'm in Moses lake and have a custom SN I need painted!
i use to paint long time ago,but now i just do it as a hobby.
