Just bought a tnt pipe. No where to put a battery?
Any one have some pictures of mounting options for batteries?
I only went through 4 ballistic pos paper weights. I much rather my agm Walmart battery. So if there is a pic of a led battery and tnt, power factor, rrp pipe installed I would like to see it.
Sent from my SAMSUNG-SM-G890A using Tapatalk
mike b
California
what hull? I put my battery on the manifold side in the back but I have an antigravity and haven't had an issue. I am sure with a small enough walmart battery you could put it in the back of the hull. Like a size 12 motorcycle/marine. Ive used this before as a spare and in a superjet and cranked over motor just fine but also was stock. If you have total loss I probably wouldn't recommend. What hull, motor, and fuel cell do you have?
mike b
California
I had a Chan last year with a pfp pipe and kart tank. I used a wps on the back corner which slid right past the exhaust manifold. Sold the ski otherwise I'd get you some pictures. The battery I used was like 3lbs, didn't last as long as my AG but I also over charged and drained the charge too low too many times. I can't see the model number on mine bit I think they were like $130
Edmond ok
I had a AGM in the chan in the back corner. It barely fit between the side of the hull and the cooling line. But that held it from side to side. Just put thick foam under the battery, screw a hull mount to the bulkhead right above the battery and run a strap from that to the motor mount.
Here is my dvx, it's similar. Just foam under it.
Here my setup on my 2015 edge FR. Fits DEKA 9, 12 or 14
Sorry the notes are in french
Did this in my XFS with the XFR tray.
Blowsion Battery Box Riser
Custom made battery holder (for sale)
Sent from my E6853 using Tapatalk
I stuffed it in front of the cart tank.
But to have it done pretty and right I have to spend $$$ it sounds like for a small battery and bracket
Mesa AZ
Yes, Spending money either way.... I HIGHLY Recommend Limitedslip7 gas tank.... Battery right on top, don't need an expensive battery or hold down. For $100 more you get a real metalgas tank with phenominal quality, and the easiest to get to battery situation you could have ever dreamed... Genius design!
