Kammander k1 1200 triple
tntsuperjet
Georgetown ca
image.jpgCustom tank filler using Blowsion superjet tank insert and TNT adapter brackets for both the pole mount and gas cap
Tuscaloosa, AL
Knew that, did not know if this was a special project between them and you for Dustin. Even though he could probably still beet everybody riding a kawi 300. Lol
tntsuperjet
Georgetown ca
Stock sxr tank.
The engine paint is army green, it's normally sprayed on with thin coats so it dries flat finish. But I did 3 coats with short dry time and heavy last coat to get semi gloss.
That's what all the WWI navy planes where painted with inside
tntsuperjet
Georgetown ca
Yes thanks BK.
List of goodies.
Tnt ported cases with ADA angled reed spacers, TNT ported cylinder,cyl resleeved.
Tnt sequential fire live tuning total loss ignition, with 3D mapping and data logging.
Novi 48mm carbs, crank works crank stock stroke, macc racing bullet girdle head, V force reeds, Blowsion handle pole with SJ billet pole beaket, custom bullet hood pins, Blowsion steering system, Blowsion HD steering cable and trim cable, Blowsion superjet inboard filler cap with TNT billet adapter. Sxr fuel tank, Jetrim mat kit with kicker, TNT triple wet pipes, with TNT billet exhaust manifolds. Kommander k1 hull, scoop grate and ride plate.
skat 12 vane setback pump with trim system,
