ksmith83
( o Y o )
- San Jose/San Mateo, CA
what is the recommended torque for the head bolts for a kawasaki 650?
21 ft pounds
run then down to 10 ft #
in the pattern then repeat at 21
1966 W1?Will this setting work for a 1966 W1? I'm about to pull the head from mine for bead blasting and inspection.
1966 W1?
There maybe someone here with info, but this is a jetski website......It's a Japanese clone of an A10 BSA. The series are the only pre-unit bikes the Japs ever made I think. Pre-unit means separate engine and gearbox in case you didn't know.
Sure..... I think...But all Kawasaki head bolts take the same torque right?
No worries, Get a Jetski and come hang out!!!!!!! They dont hurt as bad when you fall......................... errrr, most of the time at least!oops I searched for w1 head torque and was led here. My bad.
