Other Kawasaki & Yamaha Flywheels 61X – 62T - 64X - 66E - 65U - 650 - 750 - 800
I have a few questions I don't know very much about flywheels. After it is lightened do you have to advance the timing at all?
stagesrt4
see ya out there
St Charles IL
unrelated... you can advance your timing if youd like tho
there is no other mod or adjustment needed from just adding a lightened and/or lightened/drilled flywheel..
having the magnets removed to go Total Loss is a different story
Plano, TX
Another gorgeous flywheel by #Zero. Rad Kawi total loss
Okay thanks that makes it simple I was overthinking it
Lightened Flywheels - Reduction Nozzle Boring - Other Machine Work
Lightened Flywheel Service
$75 Yamaha 61X - 6M6 - 650 - 701
$75 Yamaha 62T - 701
$95 Yamaha 64X - 66E - 65U - 760 - 800 - 1200
$95 Yamaha 63M - 66V - 60T - 1100 - 1200 - 1300
$75 Kawasaki SX - 650
$85 Kawasaki - 440 - 550
$95 Kawasaki - 750 - 800 - 900 - 1100 - 1200
$95 Polaris - 650 - 700 - 750 - 777 - 800 - 1050
$95 MSD Total Loss includes ring gear pins
Lightened Flywheel Outright (no core required)
$115 Yamaha 61X - 6M6 - 650 - 701
$145 Yamaha 62T - 701
$145 Yamaha 64X - 66E - 65U - 760 - 800 - 1200
$145 Yamaha 63M - 66V - 60T - 1100 - 1200 - 1300
$115 Kawasaki SX - 650
$135 Kawasaki - 440 - 550
$145 Kawasaki - 750 - 800 - 900 - 1100 - 1200
$145 Polaris - 650 - 700 - 750 - 777 - 800 - 1050 -1200
If you don't see your flywheel listed and would like to have it lightened; send me a PM (private message) for a price quote. Also have a few other lightened flywheel types available on request and the ring gear drilling is optional on some models.
For those of you just wanting to ship one flywheel the cheapest method is to use a priority mail flat rate 12.5" X 9.5" envelope and it will only cost around $5.15 to ship anywhere in the USA. The regional rate Box-A & Box-B work well for shipping multiple flywheels but they can only be found online. Discounts are available for multiple flywheels sent in the same shipment.
All lightened flywheels are each balance checked and are available in translucent colors to prevent corrosion on the machined surfaces.
Colors available & others on request: RED - MAGENTA - ORANGE - GOLD - GREEN - BLUE - YAMAHA BLUE - PURPLE - CLEAR
View attachment 186357View attachment 186358View attachment 186359View attachment 186361View attachment 186362View attachment 186363View attachment 186364View attachment 186366View attachment 186365View attachment 168343View attachment 168347View attachment 168344View attachment 187010View attachment 195181View attachment 168346View attachment 195178View attachment 195179View attachment 195180View attachment 176511View attachment 168345View attachment 168348View attachment 174263View attachment 180303View attachment 180300View attachment 189025View attachment 189031View attachment 189026View attachment 188227View attachment 188228View attachment 182712View attachment 183327View attachment 183168View attachment 187011View attachment 187012View attachment 183328View attachment 183169View attachment 186367View attachment 186368View attachment 186369View attachment 186370View attachment 181683View attachment 182040View attachment 182041View attachment 182420View attachment 182431View attachment 184046View attachment 184043View attachment 184044View attachment 187009View attachment 187008View attachment 187007View attachment 184042View attachment 189878View attachment 183742View attachment 184045View attachment 185750View attachment 190665View attachment 190666View attachment 191448View attachment 191449View attachment 191447View attachment 191450View attachment 190669View attachment 190667View attachment 186326View attachment 186327View attachment 182043View attachment 182041View attachment 185749View attachment 180309View attachment 180307View attachment 180634View attachment 180632View attachment 180631View attachment 180304View attachment 180306View attachment 196923View attachment 186329 View attachment 180635View attachment 189879View attachment 182432
All flywheels listed are lightened between .6-lbs to 2.0-lbs total weight removed and the specifications for each type are detailed in post four of this thread. Note: Aluminum flywheels are more than five times the price of a lightened stocker which are more prone to failure with cracking hubs, spinning ring gears, vibrating loose from hub heat expansion, weaker & smaller magnets that through the timing off or won't charge the battery well. A stock lightened flywheel will perform just as well or better than an aftermarket aluminum charging flywheel in my opinion because the lightest portion of the weight differential is from the aluminum hub itself which causes a majority of the problems. Alloy expands at twice the rate of steel so the aluminum flywheels need to be constantly re-torqued or your expensive investment will be ruined in seconds. There are quite few companies such as Pro-Tec, Group-K, LPW and others that lighten flywheels but none will be as reasonably priced or will remove as much total weight.
The tapered reduction nozzle boring is $50 plus the return shipping cost. Please specify which nozzle you have with the diameter wanted and if you would like to retain or delete the stock siphon tube for the factory bilge system. The last picture shows a chart of all the different angles and sizes for each reduction nozzle.
Cylinder head modifications can range between $50 to $100 plus the return shipping cost to your area. Send me a PM for the specific application options and compression numbers for each model.
Aluminum Flywheel Weights:
ATP TL Yamaha-701 = 1.56-lbs. Aluminum
RAD TL Yamaha-701 = 1.76-lbs. Aluminum
MSD TL Yamaha-701 = 1.78-lbs. Aluminum
Jetinetics TL Yamaha-701 = 1.63-lbs. Aluminum
TBM TL Kawasaki SXR = 1.85-lbs. Aluminum
RAD Yamaha 61X = 2.12-lbs. Aluminum
RAD Yamaha 62T = 2.03-lbs. Aluminum
TBM Yamaha 62T = 2.09-lbs. Aluminum
MSD Yamaha 61X = 2.22-lbs. Aluminum
Jetinetics Yamaha 62T = 2.40-lbs. Aluminum
Jetinetics Yamaha 61X = 2.50-lbs. Aluminum
Jetinetics Yamaha 62T = 2.62-lbs. Aluminum with Steel Hub
Jetinetics Yamaha 61X = 2.68-lbs. Aluminum with Steel Hub
TBM Kawasaki Big Pin = 2.18lbs. 750-800 Aluminum
Lightened Flywheel Weights:
LW MSD TL Yamaha-701 = 1.28-lbs. Aluminum
LW MSD TL Yamaha-701 = 1.14-lbs. Aluminum - Ring Gear Drilled
LW RAD TL Yamaha-701 = 1.32-lbs. Aluminum - Ring Gear Drilled
LW Yamaha F3T305 61X = 2.94-lbs. 650-701
LW Yamaha F3T305 61X = 2.80-lbs. 650-701 Ring Gear Drilled
LW Yamaha F3T305 61X = 3.10-lbs. 650 VXR Thick Gear
LW Yamaha F4T316 62T = 2.98-lbs. 701
LW Yamaha F4T316 62T = 2.86-lbs. 701 Ring Gear Drilled
LW Yamaha F4T316 62T = 2.76-lbs. 701 Ring Gear & Front Drilled
LW Yamaha F4T323 64X = 3.48-lbs. 760
LW Yamaha F4T330 66E = 3.48-lbs. 800
LW Yamaha F63M00 63M = 3.34-lbs. 1100
LW Yamaha F65U00 65U = 3.35-lbs. 1200
LW Yamaha F4T368 66V = 3.48-lbs. 1200
LW Yamaha F4T 60T = 3.48-lbs. 1300
LW Kawasaki FP5502 = 4.06-lbs. 440 or 550
LW Kawasaki F3T304 = 3.12-lbs. 650SX
LW Kawasaki F4T309 = 3.69-lbs. 750 Small-Pin
LW Kawasaki F4T309 = 3.40-lbs. 750 Small-Pin Ring Gear & Hub Drilled
LW Kawasaki F4T309 = 3.72-lbs. 750 Big-Pin
LW Kawasaki F4T309 = 3.48-lbs. 750 Big-Pin Ring Gear & Hub Drilled
LW Kawasaki F4T309 = 2.86-lbs. 750 Big-Pin TL
LW Kawasaki F4T309 = 3.80-lbs. 800 SXR
LW Kawasaki F4T309 = 3.48-lbs. 800 SXR Ring Gear & Hub Drilled
LW Kawasaki F4T309 = 2.92-lbs. 800 SXR TL
LW Kawasaki F4T309 = 2.60-lbs. 800 SXR TL Ring Gear & Hub Drilled
LW Kawasaki F4T322 = 3.50-lbs. 900-1100 Small Pin
LW Kawasaki F4T322 = 3.66-lbs. 900-1100 Big Pin
LW Kawasaki F4T322 = 3.30-lbs. 900-1100 Big Pin Ring Gear & Hub Drilled
LW Kawasaki F4T322 = 2.78-lbs. 900-1100 TL
LW Kawasaki F4T322 = 2.42-lbs. 900-1100 TL Ring Gear & Hub Drilled
LW Polaris F4T310 = 4.10-lbs 750
LW Polaris Octane = 3.28-lbs. 777
Stock OEM Flywheel Weights:
Stock Yamaha F3T305 61X = 3.65-lbs. 650-701
Stock Yamaha F3T305 61X = 3.74-lbs. 650 VXR Thick Gear
Stock Yamaha F4T316 62T = 3.76-lbs. 701
Stock Yamaha F4T323 64X = 4.14-lbs. 760
Stock Yamaha F4T330 66E = 4.14-lbs. 800
Stock Yamaha F63M00 63M = 4.04-lbs. 1100
Stock Yamaha F65U00 65U = 4.04-lbs. 1200
Stock Yamaha F4T368 66V = 4.15-lbs. 1200
Stock Yamaha F4T 60T = 1300
Stock Kawasaki FP5502 = 5.08-lbs. 440 or 550
Stock Kawasaki FP5504 = 5.64-lbs. PJS-550
Stock Kawasaki F3T304 = 3.76-lbs. 650SX
Stock Kawasaki F4T309 = 4.40-lbs. 750 Small-Pin
Stock Kawasaki F4T309 = 4.44-lbs. 750 Big-Pin
Stock Kawasaki F4T309 = 4.48-lbs. 800 SXR
Stock Kawasaki F4T322 = 4.20-lbs. 900-1100
Stock Polaris F4T310 = 5.00=lbs.
Stock Polaris Octane = 5.28-lbs. 777
Note: All flywheel weights listed are plus or minus 0.03-lbs due to balancing variations.
I have a 03 octane would like the flywheel lightened and the domes shaved .020 down with the domes reshaped. Do you port as well? I live in Canada and can ship to you. What kind of payment will work for you? Just give me a number so we can talk. Thanks Chris
Go to the first post on this thread and click on Zero's avatar. It should bring up his details. You should see an envelope or something to that effect (I'm using Tapatalk, it might look a little different if your using a different app or computer) Click on the envelope and send him a message.
arizona
Zero i have a 64x and 62t flywheel along with a kawi 650 and 750 i need done can you P.M. a quote and approximate turn around time? Thx
