Freestyle Lead 110 or
i watched a documentary on the invention of the internal combustion engine. motors kept blowing up and everything known to man was added to the fuel. lead was the stuff that kept them together. thats why lead was in gas and for no other reason. neither high octane fuel or lead make HP. your motor either needs it or it doesnt. i know a lot of guys that use it, dont need it, but thats their choice for not knowing when its needed and when its not.
If you are needing the extra octane run avgas. Buy it at you local airport and search prices at www.airnav.com Its leaded and has a mon value of 105. Trust me I have heard all the myths........"its a dry fuel"......"it not made for lower altitudes"........ect. I have run it in 4 wheelers, and boosted snowmobiles for years. Some race gas in the can you never know what your going to get. Avgas is much more consistent IMO. If you don't need the octane, to much octane will generally hurt your throttle response.
XFT LOU
1 hp./1.83lbs
St. Louis
I had 180 psi with ada 28 domes.
I installed 26 domes, with all new O rings . I have not checked comp. yet.
But got 5 gal. Of 110 leaded. I'm guessing I will need the increased fuel .
Just a few rides on new full spect. 49's
And lighten the ski 11 lbs with a Ballistic battery .
Wave rave ....
