Leaky Scuppers???
Kennay
Squarenose for the _____
Myrtle Beach, SC
it looks like you slide it inside of your already existing 2" scupper tubing. I'd assume you remove your scupper, slide that in, and then put the scupper back on, or either you could slide it into your plumbing on the inside of the hull
TB
NOTHING IS EVER PROMISED
Grand Rapids, MI
ou take your scupper off, slide it in the tube then turn out the little set screws to lock it into place..done
no need to reinstall old scupper
