fwi
X-
- Cape Coral FL,
How do you like your 2008 SJ so far. Is the handling that much different from previous models? Any other comments welcome.
well do a search..
its totally different in handling and hookup. think sxr carvy with sj everything else.
Its alot different than the old round nose and alot diff than an sj with tubbies. Riding around it feels kind of like an fx1 that doesn't porpose and has killer hookup. It carves hard and doesn't have that feeling like you get with tubbies like they are grabbing the water. The nose stays up through corners and doesn't dig in or turnsub. Its kind of the opposite of an sj with tubbies in that you find yourself pushing the nose down through a corner rather than pulling on the bars to keep it from turnsubbing. The hook up is probably the best part, better than your typical AM prop with an AM intake grate. The rideplate looks like ******** and the stock grips are horrible. I don't understand the rideplate. It has two big holes in it that don't do anything. I hope some 2008 specific parts come out rather than just rideplates with holes in different spots.
the rideplate is an old off the shelf part at yamaha. it's a square nose rideplate, they just don't use the rear holes. they had to use it because of the set back pump pushed the rear holes off of the back of the ski so the 4 hole plate from the rn wouldn't work. you'd think they'd make a new plate but I guess they ran out of money.
I guess it's like any other..... "this year's model is totally redesigned " anything.....wait until the second year of production, maybe, so they can work out the bugs/kinks in it?:shrug:
the steering cable has less throw too and the upper part of the handlepole is different. I just bought an older style steering cable for mine.
You need an older style handle pole too. The distance between where the steering plate mount and where the cable mounts is shorter, if you put the old cable on the fx1/2008 pole you won't be able to turn left. I think the best bet for more throw is going to be at the nozzle end. Pro-tec & Riva make exteded quick steer nozzles.
Well it's me too! It's really nice in rough water but on glass it chine seeks at 15 or 20 mph worse than an antique 750 at 45 mph! Tried different ride plates, no help.Not happy so far. Bought a used 2008 recently, corners well but a lot of nose push at speed and feels darty at high speed. Throttle let off causes nose to dive and spray over bow. Hardest ski to ride well that I have been on and I have owned square nose SJ 1995 and SXR kawasaki and SXI-PRO. This may be great for a hopped up race machine , but for a stocker its not fun. Anybody else feel that way or is it me?
