Mark44
Katie's Boss
- 100% one place
what mattE said...i dunno what its called. But i took it off the top most outter
Did you drill holes to balance?
Mark44
\LOL well I know this but what is it? What it the equipment?
Mark44
Mark44
He seemed to imply it was still in good balance after he was done.
When they lighten the outer edge of the flywheels it cuts threw the balancing holes.
To be honest with you I don't think that anyone is rebalancing the flywheels after lightning them, even though they should.
An easy way to check balance is to use a lawn mower blade balancer.
Looks like this.
Doug
LOL Yea.
Mark44
Why wouldn't it work? A static balancer like that would be better then nothing, no?
Doug
You would never be able to balance a flywheel with that static wheel balancer properly.
It requires a very expensive machine call a rotation balancer and the part has to be spun around at a high speed in order to obtain the balancing measurements.
I balance my impellers and flywheels with a modified version of a Du Bro model airplane prop balancer. The steel supports were replaced with non-magnetic SS.
Also,I have a special larger diameter hub with aluminum cones to center the piece being balanced. Model airplane motors spin well over twice the RPM any ski motor can. So far it's worked really well for low $$.
No more numb feet from a out of balance impellers. :doh:
http://www.shopatron.com/product/part_number=499/101.0
Where do you take the metal off the impeller for balancing?
