chixwithtrix
Addicted
- Houston
My current setup is done for, hundreds of hours and I just got into racing this season. Looking to race in the women's limited class and I got some unfortunate news about my current Group K setup that the previous owner had done.
I talked to Group K and they poo pooed the idea of a limited boat (not surprising), but since it needs a rebuild I wanted to go limited since there isn't a stock women's novice class available.
I was hoping I'd be able to get the Group K cylinder re-sleeved, but they told me the ports would no longer match. So I'm left with a GK cylinder at the end of it's life. They recommended I start over with a new cylinder. I also need to replace the crank and head. So. I'm making this thread to get opinions.
I'll be going with an OEM Kawi crank
Have a Factory dry pipe
Should I buy a new cylinder or find a used one and get it sleeved for a little more bore, but stock porting?
Head...I guess I'll need to go girdled head with the heavy dry pipe. Thinking ADA unless someone has other input?
Carbs, currently have stock 38s, should I re-jet or get dual Mikuni 44s?
Thanks all, I'm new to working on jet ski engines so forgive my ignorance.
