- Mansfield Ohio
Not a mechanic by any means, but am noticing a little hesitation from idle to full acceleration. Once at speed the ski run fine.
Any feedback thanks.
does it idle fine in the water? what do the plugs look like? put 2 new ones in and go ride it for about 20 minutes then look. i had a problem with mine, the idle was a tad low and when i let off to get back on it it was almost trying to die, then pick back up. so i turned the idle up a tad, i probably "covered up" the problem more so than fixing it. but it idles correctly in the water and responds correctly, so i left it.
If it ran well before this there is no need to start turning mixture screws. Check internal and external fuel filters.
This is very true, if it was fine then started this and there has not been a rapid change in water temp. then it very well could be a filter issue.If it ran well before this there is no need to start turning mixture screws. Check internal and external fuel filters.
