- Goodwood, ON
OD should be 2.5” for the through hull tube
" I have both a stock SJ and an aftermarket hull where 2.5" tube was used in the hull, and the hoses for an SJ won't fit the 2.5" through-the-hull tube. ."
Because the OEM SuperJet Exhaust Rubber Hose is 2-1/4" ID...I just put the Calipers on it
So is the STOCK Yamaha OEM SuperJet Exhaust Metal Tube 2-1/4" OD or 2-3/8" OD? Imma' getting confused
It's 2-3/8"." I have both a stock SJ and an aftermarket hull where 2.5" tube was used in the hull, and the hoses for an SJ won't fit the 2.5" through-the-hull tube. ."
It's 2-3/8".
