I can measure up a 550 coupler tomorrow for length, I have a stack of those things somewhere hereIt looks like the engine side coupler is standard length and the midshaft side coupler is the extended portion, which won't work for me because I am using a Kawasaki driveshaft rather than Yamaha midshaft.
Those are Cold Fusion coupler for a Rickter.I have a set of the extended RRP couplers. Let me know if you want them View attachment 419598
I have a stack of them too the issue is the location of the built up part that goes through the thru hull bearing varies from shaft the shaft so it's not just driveshaft length you have to keep in consideration. SXR 800 driveshaft is already 27 1/8", I believe the only shaft longer than that is in a X2My offer is still open to check the other the other kawi shafts I have but I need to know lengths to compare...
Sean
No doubt, it seems like the solution since we would be going longer (closer to the engine) would be to just add a spacer between the thru hull mount plate and bearing assembly.I have a stack of them too the issue is the location of the built up part that goes through the thru hull bearing varies from shaft the shaft so it's not just driveshaft length you have to keep in consideration.
I don't have any 1" aluminum nor do I have the tools to properly build a bearing housing spacer.No doubt, it seems like the solution since we would be going longer (closer to the engine) would be to just add a spacer between the thru hull mount plate and bearing assembly.
Everything still seals up properly on the shaft and hull.
A 1" aluminum plate and some longer bolts is way cheaper than a custom shaft or coupler.
Sean
I am assuming the pump location is fixed, so adding a spacer behind the pump you will lose engagement of the driveshaft to impeller equal to however thick the spacer is, in other words you would need a longer driveshaftFair point. Carry on.
I saw on Rhaas's website that there is apparently a 1/2" spacer behind the thru hull on the SXR but I can't find that on the oe parts diagrams.
SXR 1100 Bearing Assembly
www.rhaasproducts.com
Has anyone come across one before?
I did find a 1/2" one on ebay for ~$30
Kawasaki SXR 800 / 1100 Conversation Parts - Bearing Spacer | eBay
Waterjetted and machined, mill finish, 1/2" thick alum plate, drive shaft bearing housing spacer utilized in a Kawasaki SXR 1100 conversion so the bearing seat location on the new drive shaft align with the location of the bearing housing.www.ebay.com
Sean
Nice find! I got excited for a minute because the X2 driveshaft is a good length for the application and probably easy to find BUT it would require a 3" spacer on the bulkhead which I have no way of making, I also have concerns about the load that spacer might put on the bulkhead.Fair point. Carry on.
Sean
The only shaft longer is from an X2, at any rate the total length on a 550 coupler is 2 1/4" and I have one in handYou would use a longer driveshaft from a runabout in place of the sxr stock shaft. You install the shaft fully into the pump as stock, then use a spacer between the hull and thru hull bearing to ensure the bearing sealing surface on the shaft matches with the seals in the thru hull.
All of that depends on if the runabout shaft is the correct new length though.
Sean
I'll have to find the info again, I think 28". I believe only the X2 is longer.What's the length on the sxr shaft? I wonder how a 550sx shaft would work as the splines are all the same.
