wsuwrhr
Purveyor of the Biggest Brapp
- Alta Loma, working in Upland
Never a dumb question if you don't know the answer.
I machine them for two different types, or per what the client wants.
The 10-12 mm cases typically get SJ style reeds, the 16mm cases are changed slightly in the intake tract and get a different style.
You are correct, since I am making the case, the choices are endless.
Thank you for your kind words. I appreciate it.
Brian
Brian
I'm probably about to ask a dumb question, but it wouldn't be the first time so why not.
Are those made to fit the standard Yamaha reeds? Seems like for the huge 1200 motors you would probably want something bigger, and since you're machining the case you can make it fit whatever you want.
Edit: and I also find them to be beautiful droolworthy chunks of artwork.
