- North Carolina
Looking to see if someone knows the size or mc master part number for the needle seat oring? I would like to order up some stock.
did your o-ring fail before the needle tip wore out? seems odd
Off topic, but does anyone else have premature n/s failure on these high compression high strung engine setups? My comp ski goes from clean popping to dirty pop in 3-4 rides, but i can run an oem carb set on a 701 for years?
When my blaster used to vibrate badly I was going through a lot of needles. I also ordered a couple of brand new mikuni oem needle/seats from iboats and they only lasted 1 trip to the surf..
The size is: 7.5mm inside,10.5mm outside- 1.5mm thick. Since it is for a static application, a rather "soft" compound would be indicated. Since there is a bit of ethanol in the gas, additional chemical resistance would be nice. I just "repaired" a set of 38's for a friend, came out of a running-older- ski that would let the crank case fill with gas when parked/stored. Needles looked as new, seats were so stuck, I had to drive them out from the other side (corrosion). The o rings were half (!) eaten away and not sealing, so.......I just ordered 100. I let yall know how it fits and the size.
I strongly suggest to use something better than a plumbers (no offence intended towards the low cut jeans crowd) o ring, maybe this: mcmaster. com 1295N157
i'm buying 50 of them if someone doesAnyone have a source on just needles?
10-4, as soon as someone sells them separateYou get the needles I got the o-rings
@JetManiac give the people what they want! =)10-4, as soon as someone sells needles separate
Lol, n/s orings in stock at JM separately. Needles are not available separately from Mikuni.
