lowering a stock hood
sj, cali
im going to attempt to lower my stock hood. does anyone know of any threads or sites that might give me a guiding hand? any impute would be most appriciated!!
D-Roc
I forgot!
My buddy steve did it to his stock hood. It didn't look great but he didn't go crazy on the project either. I've seen other hoods done some what the same way. it would look best with a x-metal pole.
stanton
High on jetskis.
atascadero,ca
thats so weird, i was just thinking about if anyones done it/how much effort it takes.
if/when my hood breaks ill give it a shot.
G
Goose
Guest
i did it before and turned out nice they need to be reinforced after you lower them.the hardest part is if you put the humps in the back over the air intakes.it tough to get them symetrical.im gonna go back thrue the notes i wrote down when i did mine and do a write up here later today.i also have a mold for a lowered nose peice if anyone is interested cause i know their expensive.
orlando
ive chopped down two of my RN's
not too easy but cheap and strong as you want it to be :)
im about to do another so ill take some pics and show em.
orlando
as for the nose peice....
tape off the ski and pour some foam then shape it to flow with your new hood shape...then wrap it in some glass = nose peice
D-Roc
I forgot!
draw a line, cut on said line, fiberglass over new gapping hole, paint. personally i would skip the paint but some people like nice pretty boy skis.
orlando
also have to remove the center channel and fire extinguisher junk.
just tape of a desired shape or line for both sides and try to keep the sidewalls of the inner channel so you have a guide to glass around.
WAB
salty nuts
coastal GA
One of the guys I ride with did his own and is beginning a second one now. Here's the finished version of the first one. He did it w/o removing the liner. But sorry, he's 'only' a lurker here and does not post.
yamanube
This Is The Way
Staff member
Mandalor
So after you cut the top off of hood do you obviously cant just bridge the void with glass...how do you get the contour on top?
2lick
Brap!!!
Limerick, PA
i lowered my sn hood, would pics of that help, i took pics the whole way throught.....
