Super Jet m8x1.25 to m10x1.25 Stud - 62T Cylinder - B Pipe
I'm installing a 62t motor into my superjet. My B pipe manifold accepts a m8 whereas the 62t cylinder is a m10. Does anyone know where I can buy a m8 to m10 stud with 1.25 pitch?
What other options are out there for converting to m8 from m10 1.25?
waxhead
wannabe backflipper
gold coast
you even have the right thread in the 62t cylinder. Its screws right in , no taping to do. If it takes more than 10 minutes you are doing it wrong
Stock for stock you won't notice much difference with the stock exhaust. 38s are good because they're very easy to set up. 44s can be set up several different ways depending on how you want it to run. 38s will generally have slightly better bottom end response buy will fall flat where as the 44's will keep pulling.
