grezzmky
Suckin paint fumes
- Saint Louis MO
Very shortly after getting a 144 12 vein I sucked up some rocks and locked up the pump. had to disassemble it on the bank at the lake as it was totally stuck. I used the ski for two seasons before pulling it apart for my new BAM hull. Well, the pump is banged up. I guess I will try to straighten the stator out and send the prop in for repair, that's fine.
My questions are
The mag pump came with a wear ring with liner that got trashed so I ordered an SBT one and it works and is VERY tight. This wear ring doesn't have the flange on the exit side so there is a ring. should I use this or the factory one I have that is in pretty good shape? I have seen other people talk about some spacer needed with Solas MAG, what is that?
My Midshaft is tight but (clear) water came pouring out of it when set at a certain angle... Should I rebuild it or replace it?
Is the Protec trim going to cut it? I have never had trim before but I am going for backflips this year. I have a never used Protec but I don't understand some of the workings of it. I have two different cables but they both seem maybe too big..?
My exit nozzle was supposed to be bored to 85mm, when I measure with HF digital micrometer it says 84.5 so not sure about that but the Protec is defiantly smaller. Should I go straight to the machine shop and have it bored?
THANKS
My questions are
THANKS
