Part Out ***Make me an offer on the remaining items 08/08/20.*** Getting out of jetskiing. Selling all my spare Superjet parts, tools, gear, etc.
Everything is in good working condition unless otherwise stated. Shipping not included. Prices are in USD. Please PM with your zip/postal code if you are interested in buying something.
Exhaust coupler 3.5" (Brand new/never used) - $10
Superjet Flywheel (Mint condition) - $60
Superjet Voltage rectifier - $10
SOLD - Quick Silver full length wetsuit 5:4:3 like new medium - $50
SOLD - Superjet stock 144mm pump stator - $30
SOLD - Fuel tank compression fittings (6) - $10 for all of them.
SOLD - Superjet Ignition Coil - $30
SOLD - Superjet stator (One coil replaced) - $75
SOLD - Superjet stock 144mm pump stator with stubby cone and dual cooling - $30
SOLD - Superjet stock 144mm pump wear ring - $40
SOLD - Superjet driveshaft - $90
SOLD - '08 701 62T motor. Hasn't been used since 2013. - $750
SOLD - Giro Remedy Helmet - $50
SOLD - Blowsion AF frogskins x 2 - $10
SOLD - Rebuilt starter (feels a little rough when turned by hand) - $50
SOLD - Rickter Scupper flap and ring and spare flap- $35
SOLD - Skat Trac 144mm 13/17 small hub impeller with prop tool (mint) - $150
SOLD - Assorted water bypass outlets and bilge outlet - $20
SOLD - Superjet CDI 62T x 2 - $35 each
SOLD - Assorted jets, N&S, springs etc - $25
SOLD - Versa plug ball type scupper 2" diameter- $25
SOLD - Superjet Starter relay (new) - $20
SOLD - Pop off pressure pump - $30
SOLD - Blowsion back flush (dual outlet) - $20
SOLD - Superjet oem steering cable - $75
SOLD - Superjet OEM throttle cable - $50
SOLD - Lots of assorted Superjet gaskets - $40
SOLD - Superjet stock impellor (mint) - $50
SOLD - Superjet Fuel tank straps (one long, two short) - $10 each
SOLD - Superjet OEM motor mounts x 4 - $30 each
SOLD - Superjet intake manifold - $30
SOLD - Protec Superjet intake manifold - $30
SOLD - Superjet Mikuni carb rebuild kit x 2 - $25 each
SOLD - Superjet Start/Stop switch and cable - $90
SOLD - Superjet midshaft couplers - $20
SOLD - Retriever bag - $25
SOLD - Blowsion finger throttle red (new) - $35
SOLD - Cold Fusion drive alignment tool, Cold Fusion flywheel removal tool, prop removal tool, and two other tools that I don't remember what they do. - $100
SOLD - PET-2100DXR tach - $85
SOLD - Dasa black head (no domes), black power valve covers and intake and exhaust block off plates - $30
SOLD - Dasa power valve rebuild kit - $30
SOLD - RRP pole spacer red - $15
SOLD - Rickter Tour Coat (medium) - $30
Sent pm on these:
yamabro
GP Performance / Patterson Powersports
Dickson, Tn.
I’ll take the DASA stuff,... Head, Block off stuff and the
PET-TACH also
Both Mikuni kits &
RRP pole spacer
