Looks like it's going to be honeycomb.
Started this plug by taping off the hood and waxing the inside. I then sprayed PVA on the inside and outside.
Once the PVA set I glued on some foam.
Cut more foam to make the rough shape of the liner. Added some two part foam to seal the XPS and fill in the gaps.
Lots of sanding and body filler later I had my shape. Metallic tape went over the plug and then wax.
4 layers of 8oz twill
Cut a hole in a piece of 3/4" plywood. Taped the glass plug down and the layered body filled on the back to seal the edges and hold the glass to the plywood.
Some more body filler and sanding later.
Hit it with a poly high build primer.
Was really disappointed with the PPG poly high build. Lots of undissolved solids even after shaking and mixing with a drill. It laid down OK, but for $40 a quart and that quart only lasted this one plug, I don't think I would use it again. We will see once I get to sanding tomorrow if it actually saved me any time vs just using glazing putty and going straight to Duratec.
Also started on the pole today.
It will be shorter than that. Probably 32-36"
