Does well and there's a plan for that to for added protection.Probably nearly 40-50% lighter but I have no idea on how it fares with saltwater.
Sweet. How much lighter is titanium bolts vs Stainless steel? Is titanium just as saltwater friendly as 18-8 SS?
Ooooh and then laser engrave your logo on the heads Nate! If I ever get my machine running again I could help....
Another action pic. ...i gotta get a gopro case for inside cnc! View attachment 289592
sent from my iphone-killing Galaxy S6
Is there someone else developing something similar? If so, I was unaware.The first to the ball valve style is the winner, you will see clones everywhere...
Anodizer is finally put together. Took a lot longer to build than I expected. Still need to buy a set of female test leads to connect the output.
Not the cleanest install, but it works. I'll get around to wire management eventually, and buy some face plates for the switches.
Still need to build a rack to hold the tanks. In total I'll need 6 tanks if I want to run both titanium and aluminum without dumping chemicals. Going to crowd an already crowded work space. Also need to figure out an immersion heating and cooling solution for the aluminum line.
And here's some more pictures of the nozzle and trim development.
Employee w access... i have a really cool boss
You should bring that to school. You'll get a free trip to the White House.
that like was for your cool boss, be sure to let him know. But you can get a like too if you make me some cool stuff! =)
