Ok so the oil injection was for sure blocked off, the pump was replaced with a block off plate on the flywheel cover and the rest of the system was all looped off. Yeah the oil injection is a bit different on my wb2 than your wb1 there. Mine had way less outlets on the tank. And yes i'm getting 150psi in the front cylinder and 145psi in the back. I'm going to pull the motor and replace crank seals now and hope I don't run into any more problems. Still never figured out why it wouldn't start though, deal with that when I get it back together I guess.
