Thank you, too bad I didn't see that post a few min ago. That would have saved me from typing all this for the third time:
Read early on in the thread. I'm trying to keep the weight down. My new power plant will eventually be much lighter pound for pound than the heavy stock 700-800cc engines. If you put one of those engines in a 300, it ads 45+ pounds which changes the handling and lightweight feel of the ski. Also, If you read back, you will find that I plan on putting in a large motor very soon anyways for comparison and to measure the pumps capabilities.
I plan to eventually offer a similar design ski to what I'm testing with around 50-60 stock horsepower on the EPA CARB model with a "Competition Only" option that adds almost twice the power.
On a boat, more than a bike or car, weight makes much more difference because the surface tension of water creates far more drag than a road dose with wheels. Losing 50lbs in the drive train with relatively the same HP gives a significant power to weight ratio increase. This prototype is kind of like a Lotus sports car. It's lighter, still reasonably powerful but much more economical and should have a lower initial cost. It's like comparing a motorcycle with 100hp to a car with 200hp. The bike feels more powerful but in fact it is much weaker.
Also, this ski is designed to have an EPA and CARB approved motor so it can be sold in all 50 states. To do that with a ski after December 31, 2011 will require a very heavy, expensive and complicated 4 stroke motor like a Hydrospace. Try doing anything other than racing in one of those 380+lb skis. This ski is designed as a lightweight ski that will be mass produced and sold for the same price or even less than the current models. It will be light and nimble, fun for almost anyone. With the option of bolting on tons more power without turbos or expensive aftermarket engines.
The number one goal here is to meet the EPA requirements to continue the sport. There is only one company in the US that can produce and sell the engine we intend to use due to patents. They have plans to produce a specific size engine for other uses. Until we get some of these skis on the market or generate enough public interest, we cannot expect them to produce the perfect motor size we need. This hull works with the engine available for our prototype motor. The 300 motor we're using here for now is similar in size while slightly less powerful. It's a good fit to test the hull/drive line while we wait for a motor.
