I have a 94 sn 860cc Ada engine and the exhaust side motor mounts snapped but I was still riding about ten min till I noticed. I have engine out now and when I grab on midshaft I see a ill bit of flex in the rubber of the bearing mount and a little bit of movement up and down where shaft meets the bearing. Is this normal to have small amount of movement? When engine is hooked up there is no movement at all. Thanks for the info
