What price would you consider fair for labor only to build a new midshaft assembly from scratch? Install bearing, grease and install 3 grease seals, install grease nipple/hose, press midshaft, install orings, install coupler.
How about to rebuild a midshaft assembly? Remove shaft, remove seals and bearing, cleanup, install new bearing, grease and install 3 grease seals, press midshaft, install new orings.
What price would you consider fair for labor only to build rebuild a pump stator/driveshaft assembly?
Thanks in advance for your input.
