thanks chris my mid shaft turned up today looks brand new thanks
glad you are happy!
Hey looking for a 95 blaster midshaft... Need a whole set up thanksJetManiac's Midshaft Shop
View attachment 201731 View attachment 201732
We have new and used midshafts (aka: intermediate shaft), housings, couplers, and parts for your superjet or aftermarket hull build or rebuilds. Also for your Waveblaster and FX-1.
Send us your tired midshaft assembly for repair/replacement/rebuild OR select from our components and have one custom built to your spec. We have built hundreds of midshafts and know how to build them properly.
Otherwise we can provide you with all of the parts necessary to build or rebuild a midshaft assembly yourself.
Link to our midshaft info thread:
http://www.x-h2o.com/threads/105232-Midshaft-Talk-Building-Rebuilding-SN-vs-RN-etc
Midshafts and Midshaft rebuild kits:
Midshaft rebuild kit 39.
(sealed bearing, 3 grease seals, clips, orings)
SBT SJ/Blaster midshaft only 89.95
Cold Fusion midshaft only 123.
new FX-1 midshaft 89.95
Midshaft housings:
New a/m lynx Midshaft Housing 89.
(all RN/701, 94-95 SN701, Blasters)
Used clean OEM midshaft housing 98.
Used clean OEM SN '90-93 housing 89.
New SBT RN housing 109.
(w/o bearings and seals)
New OEM yamaha midshaft housing 195. disc to 179.
(701 Superjet or Blaster)
New Cold Fusion billet midshaft housing 249.
Cold Fusion RN midshaft spacer for a/m hulls 32.
OEM midshaft housing to hull bolt kit 9.
(3 oem ss bolts with captured lock and fender washers)
Couplers and Dampeners:
View attachment 201735 View attachment 201737
Cold Fusion billet coupler set 79.95
Cold Fusion extended billet coupler set for Rickter 89.95
Cold Fusion Red urethane dampener (90A hardness) 32.
Cold Fusion Blue urethane dampener (80A hardness) 32.
ADA lightweight billet couplers
ADA billet lightweight coupler set 79.
Kawi style dampener 22.
ADA coupler midshaft side only 39.
ADA coupler engine side only 39.
ADA coupler for kawi conversion 39.
OEM yamaha used 3 finger coupler set 25.
OEM yamaha 3 finger dampener 10.
OEM yamaha used 5 finger performance coupler set 35.
OEM yamaha 5 finger dampener 13.
New OEM Yamaha coupler cover 19.
(All superjets and blasters)
Coupler cover hardware kit 12.
(oem coupler cover inserts and hardware)
Midshaft Tools and Parts:
Midshaft/Engine Coupler install/removal tool 25.
(Specify 3 or 5 finger OEM coupler tools)
Midshaft spline holding tool 19.
Midshaft Build/Rebuild Assembly Labor 60.
(housing build only 40.)
Got the midshaft back yesterday. Thanks for the quick turnaround!
@zzylstraJust placed an order for a full Cold Fusion setup for my new hull, thanks Chris for the great service!
