Hello all, i hope all is well. let me know if this is not the correct area to post this. i couldnt find an exact matching area to post this. i have 2 1995 waveraider deluxe 700, a1995 wave venture 700, and a 1997 wave venture 760. they all currently have chokes, and i bought primer kits for them. i plan to remove the choke plates and shafts to install. 3 questions for those of you who have did this:
1. which fuel line did you tap into. i have read multiple different theories on reserve OR return lines
2. how did you seal you primer fittings into the carb as i read they are loose fit? jb weld?
3. what did you use to seal the other unused hole in the top of the carb from the choke shaft? RTV, jbweld?
